Forums >> Revit Building >> Technical Support >> Render Model Lines ?
Mon, Oct 31, 2011 at 12:01:31 PM | Render Model Lines ?
kingkong
I've used model lines to show panel joints on an alucobond cladding system, so I don't have to model each panel individually.  When I render, none of the model lines appear in the rendered image. Is there a way to render with model lines?
Revit Architecture 2011
Mon, Oct 31, 2011 at 1:51:30 PM | Render Model Lines ?
No.... model lines do not render.  I would add vertical wall reveals.
Mon, Oct 31, 2011 at 2:01:39 PM | Render Model Lines ?
kingkong
I'll give it a try. Thanks!
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
model lines in rendering
Mon, Jan 22, 2007 at 3:32:38 PM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
model lines blocked by model components
Fri, Mar 19, 2010 at 4:35:47 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Page generation time: 0.7230
