Forums >> Revit Building >> Technical Support >> topography
Mon, Dec 5, 2005 at 9:33:11 PM | topography
tuffo
I am having problems with my sections, I cannot get the topography out of the building and it is not allowing me to put furniture on the floor. I am also having problems creating walkways and coloring the grass green. Also, how to make a parking lot of a sloped surface.
Mon, Dec 5, 2005 at 10:46:34 PM | RE: topography
eldados
eldados Avatar
4.5 Stars: 8 Votes
WELCOME Smile to cut topo out of your section, you will need to put a pad under the building, refer tutorial. to create walkways, you will need to use floors and ramps and if it's a complicated site, you can refer to my tutorial on creating complex slabs and walkways... to get the grass bit, you will need to split surface.
Integrator
KarelCAD
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Topography
Wed, Oct 19, 2016 at 6:19:21 AM
Topography dissapearing
Wed, Nov 7, 2012 at 2:46:15 PM
Creating levels below topography/raising topography?
Fri, Apr 12, 2013 at 1:22:50 PM
Extend topography.
Mon, Mar 26, 2007 at 8:21:29 PM
Page generation time: 0.0336
