Forums >> Revit Building >> Technical Support >> Customizing wall type properties
Sun, Oct 30, 2011 at 8:20:58 PM | Customizing wall type properties
MrMikhail
Just learning revit and having some trouble creating a more complex wall. Is there a way to set up in the type, thickenings of certain layers of a wall type at set intervals and at the ends of a wall element? i.e. If the structure of a wall I've created is concrete is there a way to create customised ribs within that layer as part of a wall.
Help is much appreciated!
Mon, Oct 31, 2011 at 7:55:30 AM | Customizing wall type properties
You can alter the thickness of materials vertically in flat segments but not horizontally.  You can also add horizontal sweeps to the wall definition.  Everything vertical must be done in-place.
Wall type properties not showing in section Revit Architecture 2012
Fri, Jul 5, 2013 at 9:17:46 AM
Customizing Families and objects
Wed, Oct 26, 2005 at 4:07:45 PM
System Wall Properties
Wed, Mar 18, 2009 at 12:55:04 AM
Properties to TYPE Properties
Tue, Dec 19, 2017 at 2:01:31 PM
"inherit properties" when starting a wall
Wed, Jan 19, 2005 at 4:36:36 AM
Page generation time: 1.4852
