Forums >> Revit Building >> Technical Support >> New pat pattern help
Thu, Oct 27, 2011 at 8:01:28 AM | New pat pattern help
angelrod
Hi guys
I've been using the information from this forum to create a new hatch pat based on the autocad pat file. I just copy the line command from the ACAD.pat and pasted it in a new Revit pat file. I changed the distance between the points and the angle to draw the hatch, but it is not showing like the dots hatch in AutoCAD, it is actually following a funny pattern instead.
I don't understand why it works differently in AutoCAD and Revit, apparently this happens only with the dots pattern. I tried with other patterns from the CAD file and they work perfectly.
See the text I included in the revit pat file:
DOTS, A series of dots;%TYPE=DRAFTING45, 0,0, .03125,.0625, 0,-.0625
Any help or advice will be appreciated.
Edited on: Fri, Oct 28, 2011 at 5:58:17 AM
Tue, Nov 1, 2011 at 8:26:43 AM | New pat pattern help
Geofflc
Not sure how helpfull this will be, but I use a addin program called hatch 22. If you google it you will get it. I use it to create new hatch patterns and if works well. Might be an option or a tool for a later use if not applicable right now.
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:04 PM
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 2:01:39 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
how create own pattern file (*.PAT)
Tue, Dec 18, 2007 at 7:46:17 AM
Page generation time: 1.6486
