Forums >> Revit Structure >> Technical Support >> Changing distance btwn grid lines with walls....
Thu, Oct 27, 2011 at 7:08:19 AM | Changing distance btwn grid lines with walls....
seniorcad143
1 Stars: 1 Votes
beams and joist.
I am just playing around with revit and trying to take in typical scenarios of everyday drafting.
Everyone knows how many times grid lines move.
Well, I have my gridlines, foundation slab, foundation walls, concrete colums, steel columns, beams and josits all laid out.  The exterior face of wall is 1' off of the grid line.  Now I want to move my grid ine 4'.
What is the easiest way to do this and have everything move/stretch along with it?  I tried moving the grid line but the foundation items did not move.  I thought once you put in dimesnions that all you had to do was change the dimension and everything would move with it (silly me),  I can not change the dimension at all, except to just override it.
(Remember I am very knew to Revit)
Yeesh - Where is My Cad
changing grid lines angle - walls are detached
Fri, Apr 20, 2007 at 6:29:43 PM
Constraints r not satisfied
Sat, Aug 23, 2008 at 8:55:07 AM
Ignoring grid lines between independent structural systems
Thu, Nov 1, 2012 at 12:00:32 PM
changing font in Grid and Level lines
Mon, Oct 2, 2017 at 9:32:11 AM
Break Grid lines
Sun, Jul 18, 2010 at 9:36:15 AM
Page generation time: 1.5092
