Forums >> Revit Building >> Technical Support >> Rendering - light blub missing
Wed, Oct 26, 2011 at 5:26:19 PM | Rendering - light blub missing
j0ker007
Quick question
I have done a few rendering for a few projects but I can ever seem to find how to have a light source so the light blub.
yes there is light bouncing off the walls and floor but no light blub glowing.  Do I need to add a something part or the family
of the light or do i have something turned off?  Any info will help.  Also I will export all my projects into 3ds max design
2012 so they will have to show up there also.  Also dont really want to replace the light sources in 3ds max unless I have to.
Thanks
Fri, Nov 4, 2011 at 12:18:16 PM | Rendering - light blub missing
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Did you apply light source to your lamps, in the family editor, some lamps may not actually have a light source. You can adjust the intensity of the light source as well as choose the shape, in the family editor. Don't know if they transfer to 3dsMax
Fri, Nov 4, 2011 at 12:31:20 PM | Rendering - light blub missing
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
this issue comes up often on here, check out this out thread
http://www.revitcity.com/forums.php?action=viewthread&thread_id=23190
Fri, Nov 4, 2011 at 1:08:08 PM | Rendering - light blub missing
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
This is also extremely easy to PhotoShop, and often times more realistic. Check out the example from a previous project of mine...
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:32 AM
rendering light source
Mon, Dec 19, 2011 at 3:50:41 PM
Rendering light trouble...
Thu, Sep 16, 2010 at 9:33:24 AM
Generic Model turned Light Fixture not rendering
Thu, Aug 2, 2012 at 9:57:59 AM
underlay
Mon, May 12, 2008 at 9:21:46 AM
Page generation time: 0.2986
