Forums >> Revit Building >> Technical Support >> Cant load Curtain Wall Door
Wed, Oct 26, 2011 at 3:15:41 PM | Cant load Curtain Wall Door
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I've been working on a curtain wall door family and loading into my project as I've made progress to cross check everything. The family has loaded fine up until now. It started when I was having trouble controlling a door level family that was in my curtain wall door family. Though there was an issue here the family still loaded. I went back to the family and deleted the handle and tried copying the generic model in instead. After that revit told me that it cant make the curtain wall when I try to load into my project. As far as I can tell there is almost nothing new from what is already loaded and what is being reloaded. Any thoughts?
Wed, Oct 26, 2011 at 3:16:17 PM | Cant load Curtain Wall Door
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Error messageElements Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Existing) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1114 : id 515519 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920866 Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Option 1) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1143 : id 516231 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920873 Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Option 1) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1152 : id 516705 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920874 Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Option 2) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1189 : id 517882 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920876 Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Option 3) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1226 : id 519059 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920877 Can't make type "CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull". (Floor 33 Schemes : Floor 33 - E7 SM) : EXISTING : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull - Mark 1419 : id 581779 Type : Family : Doors : CURTAIN WALL DOOR : Doors : CURTAIN WALL DOOR : AUS_Sgl Glass framed w d-pull : id 920894
Wed, Oct 26, 2011 at 3:17:11 PM | Cant load Curtain Wall Door
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
ooo sorry about that last thread. I was trying to attach the error report and it posted like that. It's really just supposed to be one error message that occurs 6 times.
Wed, Oct 26, 2011 at 3:26:07 PM | Cant load Curtain Wall Door
It is not one message.... Note that it shows several different door marks.  If you try to load a family that is already in the project and the updated family no longer works, you will see a message like this.
Sorry - didn't read original post.
Obviously when you deleted the handle, you deleted or messed something else up.  When you edit families with multiple types, switch through them to see if they all flex.
Edited on: Wed, Oct 26, 2011 at 3:34:05 PM
Wed, Oct 26, 2011 at 3:41:44 PM | Cant load Curtain Wall Door
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
So it looks like you cant copy geometry from a family into another. It seems to corrupt it and then even after you've purged it there's issue. Does anyone have a method for nesting a door handle family into a curtain wall door family? There's a lot of problems when its done with simply inserting it. Suggestions?
Revit refuses to load curtain wall door.
Tue, Feb 9, 2010 at 12:55:10 PM
Curtain Wall Panel to Curtain Wall Door
curtain wall doors
Fri, Mar 24, 2006 at 8:34:08 AM
Cannot place door in curtain wall
Wed, Feb 3, 2010 at 11:57:47 AM
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Page generation time: 1.3235
