Forums >> Revit Building >> Technical Support >> How to hide/trim mullion corner edges
Wed, Oct 26, 2011 at 3:49:40 AM | How to hide/trim mullion corner edges
busterdk
Hi there
When designing/sketching openings/windows in a building im often using "Curtain Walls" instead the often more static "Windows".
But when placing mullions its often to much detail that Revit shows each individual mullion element instead of showing them as one continuous shape like mullions i regular "Windows" do.
Ive attached a picture for you to see what I mean....
Hope you can be of any help...
Best regards Mikkel, Denmark
Wed, Oct 26, 2011 at 7:32:25 AM | How to hide/trim mullion corner edges
The mullion joints are switchable so you can change wich ones are continuous.  Just click on the mullion in elevation and you will see the switch.
cleanup horizontal mullion at corner mullions, again....
Wed, Jan 8, 2014 at 11:14:49 AM
Horiz mullions wont clean up because of angled corner mullion
Wed, Oct 1, 2014 at 8:43:20 AM
connecting horizontal mullions around a corner mullion
Thu, Nov 17, 2011 at 12:38:25 PM
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
Page generation time: 1.2268
