15 Users Online (13 Members):
Forums >> Revit Structure >> Tips & Tricks >> stair plan
45 Posts No Rating |
hi,
why everytime i create stair (monolitic) and see it from level to, the steps beyong cut line is still continious line NOT dash or hidden line?! also the break symbol is not showing on the upper level plan of the stair, it only shown in the lower level of stair plan
"Pleasure in the job puts perfection in the work"
- Aristotle |
check two things, draw a section through your stairs, verify that they are indeed going the direction that you thought they were. then make sure that you are on the correct floor, and that your veiw range is set properly.
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN |
Fri, Sep 2, 2016 at 7:03:03 AM
stair not showing up as it should be in plan region |
Fri, Oct 30, 2009 at 11:46:34 AM
Plan Regions Cutting Stairs |
Thu, May 26, 2011 at 6:14:12 PM
Can“t see entire stair |
Fri, Sep 13, 2013 at 2:16:00 AM
Stair Plan Enlargements |
Mon, May 7, 2007 at 6:33:41 AM
