Forums >> General Discussion >> Revit Project Management >> fillet arc on stairs
Tue, Oct 25, 2011 at 6:54:37 PM | fillet arc on stairs
emorocks
hi.
i have a doubt, i am doing a monolitical stair and will like to know if there is an option to have it with a fillet arc on each tread?
i think i kind of explain it on the attached image
Tue, Oct 25, 2011 at 7:55:41 PM | fillet arc on stairs
emorocks
it doesnt has to be an arc it can be a line on 45°
Wed, Oct 26, 2011 at 7:25:28 AM | fillet arc on stairs
Look at your stair properties and your HELP:
Nosing Length Specifies the amount of the tread depth that overhangs the next tread.
Nosing Profile
The profile for a sweep added to the front of the tread. See The Families Guide. Also see Creating a Sweep. Revit Architecture has predefined profiles to use for the sweep.
Thu, Oct 27, 2011 at 1:35:36 PM | fillet arc on stairs
emorocks
yeah i tried that but i need to have a cut out on that corner of 45°, the nose will come out the thread
Thu, Oct 27, 2011 at 2:20:55 PM | fillet arc on stairs
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
try making a profile similar to the attached. This nosing is kept within your tread dimension.
Fri, Oct 28, 2011 at 12:39:35 PM | fillet arc on stairs
emorocks
nice! thanks!
Fillet arc not working on baluster panel extrusion
Wed, Oct 26, 2011 at 5:56:34 AM
Convert wall from thick to think at corner fillet-arc
Fri, Aug 11, 2017 at 8:03:41 AM
Adding fillet to circle mass
Tue, Jun 5, 2012 at 6:29:31 AM
How to create Arc stiars..
Thu, Feb 2, 2012 at 1:22:48 AM
Stacked wall problem - corners do not fillet.
Wed, Jul 16, 2008 at 11:40:39 AM
Page generation time: 1.0920
