Forums >> Revit Building >> Technical Support >> Rendering Accurate Colors
Tue, Oct 25, 2011 at 9:44:50 AM | Rendering Accurate Colors
romanosyr
im rendering an exterior perspective and trim needs to be white no matter what material i assign, even White PVC, when the rendering goes through it looks beige or tan. any advice?
Tue, Oct 25, 2011 at 10:14:53 AM | Rendering Accurate Colors
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
alter your shadow angle, maybe its on the 'dark side' of your building. Tinker with your exposure controls too.
Wed, Oct 26, 2011 at 8:14:44 AM | Rendering Accurate Colors
romanosyr
yeah ive tried all of those option even in direct sunlight it comes out tan, ive tried messing with exposure but you can really only take that so far before it destroys the image.  ive messed with sun intensity in the shadows dialog but that seems to have no affect on the actual rendering.  i attached an image all the colors you see are supposed to be white.
Wed, Oct 26, 2011 at 8:36:35 AM | Rendering Accurate Colors
White is only white under direct light and no other colors around it reflecting and changing it.  The box below is white and I believe it is rendered correctly.
Wed, Oct 26, 2011 at 10:32:52 AM | Rendering Accurate Colors
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Try a metallic paint with 255 255 255 RGB and a highlight spread of 0
rendering colors
Tue, Apr 25, 2006 at 6:49:34 AM
Revit 2009 Rendering Accuracy
Wed, Oct 15, 2008 at 4:35:48 PM
Colors and Printing
Thu, Jul 19, 2012 at 10:11:31 AM
Rendering Materials
Wed, Sep 13, 2006 at 1:13:06 PM
Setting Line Colors to print in grayscale
Wed, Feb 21, 2007 at 10:21:49 AM
Page generation time: 0.2385
