18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Elevation lines
7 Posts No Rating |
So, i Want the lines of the beam edge, the floor edge and the limit of inferior and superior wall disappear in elevation "Sul", so it stays like elevation "Leste". I did one wall with the full height and no elements in elevaton "Leste" just to show how i want it to be, but with the other elements.
It sound to me like you have settings in one view that you want to use in another view to make them look similar. To to this, you need to create a view template from the view that is set up as you want it. On the View tab, click View Templates > Create template from current view, give it a name and click OK. Then go to the new view, click on View Templates and choose apply template to current view. Pick out the template you just created and it will look like the original view. (Of course, you can also change the properties of the view template, as you will see when you create your template, if you want to refine it any further.)
jlights |
Undesired Lines in Elevation |
Wed, Sep 12, 2007 at 11:38:24 PM
visibility of glass panel lines in elevation |
Tue, Aug 11, 2009 at 5:55:02 PM
elevation lines obscuring everything else (revit 2015) |
Tue, Apr 14, 2015 at 2:05:53 PM
Moving topography lines that appear in elevation down 6" |
Mon, Jul 7, 2014 at 11:11:03 AM
Elevation lines and bubbles on sections and elevations. |
Thu, Aug 30, 2012 at 2:05:14 PM
