Forums >> Revit Building >> Technical Support >> Railing wont host to stair created in design option
Sun, Oct 23, 2011 at 3:14:02 PM | Railing wont host to stair created in design option
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
For some reason I'm not allowed to host a railing to a monolithic stair that I created in a design option. If I'm in plan and I click the stair as a host nothing happens and no railing appears. In 3D view revit tells me, "No element in a secondary Option can be referenced by an element outside that Option." Which is not true because I have the design option opened that the stair was modeled in and can edit the stair sketch from here as well. Any thoughts?
Mon, Oct 24, 2011 at 7:20:50 AM | Railing wont host to stair created in design option
The railing has to be created while in the design option.
Mon, Oct 24, 2011 at 10:23:19 AM | Railing wont host to stair created in design option
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
That's where I'm trying to create it. I'm in the same design option that the stair was created in and I'm trying to create the railing. Then I get the error. What else could be going wrong?
Mon, Oct 24, 2011 at 10:43:27 AM | Railing wont host to stair created in design option
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Mon, Oct 24, 2011 at 11:18:13 AM | Railing wont host to stair created in design option
Why didn't you allow the railing to be created when you did the stairs?
Mon, Oct 24, 2011 at 2:09:54 PM | Railing wont host to stair created in design option
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Does it matter?
Mon, Oct 24, 2011 at 2:20:11 PM | Railing wont host to stair created in design option
It should not matter except you have to create the railing while in the design option and I always create the railings when I do the stairs.  Much easier to do it then.
You can't create it outside the option then try to host it in the option.
And since you seem to be having problems, why not do them both at the same time?  BTW - In order for the railing to be hosted, the sketch has to be within the confinds of the stair.  If you want it outside the stair, like a stringer, face based railing, the railing still has to be within the stair sketch and you use the offset function in the railing properties to locate the railing.
Mon, Oct 24, 2011 at 3:54:39 PM | Railing wont host to stair created in design option
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
All of that is well and good, but it just doesnt work for some reason. I guess the only solution is to build it over again to appease its will. Thanks anyway. I guess its just a glitch.
Railings and Stairs
Fri, May 16, 2014 at 12:12:16 PM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Stair will not host railing
Wed, Oct 10, 2012 at 12:19:23 PM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Page generation time: 0.5188
