Forums >> General Discussion >> Revit Project Management >> PROBLEM with assigning materials in imported components from Sketchup
Sat, Oct 22, 2011 at 1:00:57 PM | PROBLEM with assigning materials in imported components from Sketchup
LOSpistos
OK..I'm soooo desperated. I have a deadline on sunday and I'm still dealing with one issue, that I don't know how to overcome.
I found on internet sketchup component. In sketchup I deleted all materials assign to it and import to revit family, where I changed default materials to proper one. Everything was alright, but after loaded into the project the colour of component change and when I try to render it, it rendered me different material. And I really dont know WHY?? In previous revit version I was always making the same procedure and everything went OK, but know in revit 2012 It doesnt works. Maybe I'm stupid or what, but I'm getting more and more crazy about this problem..
thaaaaaaaaanks to everybody..Smile
Sun, Oct 23, 2011 at 5:01:41 AM | PROBLEM with assigning materials in imported components from Sketchup
4 Stars: 205 Votes
You have several threads about that issue if you look at the bottom of this page BUT remember: The Project Rules, after you load your family into your project, go to "Materials" and check if those materials are correct like you want.
applying revit materials to imported sketchup geometry HELP!!?
Fri, Feb 13, 2009 at 1:22:41 PM
Sketchup to Revit
Fri, Nov 19, 2010 at 3:44:54 AM
Import model from Sketchup to Revit- Materials not showing up in rendering
Wed, Mar 17, 2010 at 1:27:25 PM
Material Stretched Horizontally
Fri, Apr 24, 2015 at 11:45:13 AM
Imported object transparent faces
Tue, Mar 15, 2011 at 2:44:52 PM
Page generation time: 1.4872
