Forums >> Revit Structure >> Technical Support >> Framing Plan problem with displaying
Fri, Oct 21, 2011 at 8:09:23 AM | Framing Plan problem with displaying
seniorcad143
1 Stars: 1 Votes
I think I might have messed up and would like someone to help me out of this mess.
I have a sloping roof with a high bmd el and a lo bmd el.  I drew such on the elevation, they are 5' apart.  Anyway, when I did this it created two plans.  Well being new to Revit I drew joists and beams on both plans - the high beams on the high plan and the low ones on the low plan, and the joists that are sloping from low to high I put on the low plan.  Anyway now looking at it I would like all the joists and beams to be on one plan, so I only have one roof framing plan not two.  How can I get these to combine, I tried the view range thing and it will show the low plan joists and beams but it will not show the sizes.  Other than staring over with the framing I don't know what to do.
(As you can see - I am new to revit!)
Yeesh - Where is My Cad
Fri, Oct 21, 2011 at 8:20:21 AM | Framing Plan problem with displaying
I don't use structures but this sounds like a hosting issue.  You should be able to click on the elements not showing their sizes and re-host them to your new level.  You will probably then have to change their location based on that level.
Fri, Oct 21, 2011 at 8:51:54 AM | Framing Plan problem with displaying
seniorcad143
1 Stars: 1 Votes
That is not working - what I want to do is take the two plans and combine them into one.  So I have beams called off on both plans.  It is modeled right on the elevations and on the 3d but plan wise it is all wrong.  I would like to know how to fix this just incase in the future I need to combine plans.
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
Sloped framing and framing plans
Tue, Apr 11, 2006 at 7:47:26 PM
wood framing plan
Wed, Dec 31, 2014 at 9:10:12 PM
Framing Plan
Tue, Jan 3, 2006 at 4:10:28 PM
12
Framing Plan - Walls
Mon, Jul 15, 2013 at 7:37:48 AM
Page generation time: 2.4711
