Forums >> Revit Systems >> Technical Support >> Revit MEP 2011 Won't Export dwf/dwg Files
Thu, Oct 20, 2011 at 4:21:01 PM | Revit MEP 2011 Won't Export dwf/dwg Files
koolair
4.5 Stars: 2 Votes
Hi everyone,
I am wondering why the program won't export.
EXPORT--->CAD FORMATS--->DWG
Opens up a prompt called "Export CAD Formats - View / Settings"
I check off which drawings I want, etc....
Then I click "Next", then it stalls forever.  I can't click anything on the ribbon or the project browser.  If I hit ESC, it returns me to the first prompt window.
Same deal for PUBLISH (trying to generate a 3D dwf for viewing in Navisworks)
Hope someone could help
Joe
Fri, Oct 21, 2011 at 10:10:45 AM | Revit MEP 2011 Won't Export dwf/dwg Files
TKennedy
4 Stars: 8 Votes
Do you have enough RAM? I've had problems exporting to .dwg when working with very large files, it acts like it creates the .dwg but doesn't.
Fri, Oct 21, 2011 at 11:07:55 AM | Revit MEP 2011 Won't Export dwf/dwg Files
Try it one sheet at a time.
Fri, Oct 21, 2011 at 5:19:12 PM | Revit MEP 2011 Won't Export dwf/dwg Files
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
It can take a very long time to export, as well.  I recently was asked to export DXFs or 3D DWGs for interior designers using sketchup, and the screen froze for 2-3 minutes to export 15 mb files. And I have an excellent computer.
make sure you don't have anything like shrubs or extremely intricate 3D objects attempting to export.  A single tree can add a megabyte or two to your final cad output.
Sat, Oct 29, 2011 at 6:47:43 PM | Revit MEP 2011 Won't Export dwf/dwg Files
koolair
4.5 Stars: 2 Votes
No, it's bizarre, my neighboring Revit user can export the dwg and dwf files on this
same project no problem.  It's not like the computer is processing something.  It's
just sitting there.
I have a top of the line computer with tons of RAM.  64 bit machine.  Anyone know why
Autodesk does not enable Revit to use all cores on my duo-quad core?  It's silly...
Thanks
Export to DWF vs. DWG
Tue, Apr 24, 2012 at 3:52:31 PM
Help with dwf visible parameters
Mon, Aug 23, 2010 at 2:41:35 PM
3D DWF export in Revit 2009 does not export identity data
Thu, Nov 19, 2009 at 12:01:43 PM
Revit 2015 - Modify DWG/DWF Export Setup - Linetypes
Wed, Mar 2, 2016 at 3:02:28 PM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:11 AM
Page generation time: 2.5222
