12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> flat channel top of steel
3 Posts No Rating |
When I place a channel shape flatwise and use the level offset tag to note the top of steel elevation, the top of steel is based on the object component endpoint. Is there a way to get the top of steel to be the backside of the web?
10 Posts No Rating |
There isn't a setting or anything. You just have to offset the distance x̄.
Edited on: Thu, Oct 20, 2011 at 2:48:09 PM
3 Posts No Rating |
If I offset the channel member, it will be located correctly in section view, but the level offset tag will be incorrect. Unless I am missing something, you cannot use a level offset tag to locate top of steel for a flatwise channel or for angles with unequal leg size.
140 Posts No Rating |
I think you can adjust the section to be rotated 90° and the set the lateral location to side 1 or 2. It you set the z-direction offset to center, you should have a flat channel, rotatied 90° with is location line centered on the web.
I think. . .
3 Posts No Rating |
I reframed the area and this worked (Rotated 270 degree, Side 2). Thanks!
Steel Stairs with Channel Stringers |
Wed, Jun 7, 2006 at 11:33:30 AM
flat steel frame |
Thu, Oct 1, 2009 at 3:46:39 PM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
sloped flat roof - Q2of2 |
Mon, Sep 11, 2006 at 5:25:29 PM
Wall hosted objects cutting voids into a wall |
Thu, Jun 18, 2009 at 3:47:04 PM
