Forums >> Revit Building >> Technical Support >> Revit 2009 Crashing In View Template Creation
Thu, Oct 20, 2011 at 11:49:17 AM | Revit 2009 Crashing In View Template Creation
tmassey
tmassey Avatar
Searched the forum and Help for this one.I am able to make a view template in 2012. On my 2009 version I revit closes down when I modify or create a new view template.
I have tried 4 times, opened closed and the same thing. Anyone else experienced this. It happens on other machines as well.
Using Revit Architecture 2012
Thu, Oct 20, 2011 at 1:28:24 PM | Revit 2009 Crashing In View Template Creation
tmassey
tmassey Avatar
Dear AutoCAD® Revit® Architecture Suite 2009 Customer:
Autodesk has analyzed the error report you recently submitted. Errors similar to the one listed below have been resolved and are included in this maintenance update.
We recommend that you install this maintenance update to update your product, or contact your system administrator.
It is fixed thanks to this patch
 Error Report Summary
Computer Date The steps you provided Autodesk STATION-3442 10/20/2011
Steps not provided
 Maintenance Update   Improvements made in Web Update 3 build (20081118_1045):  Readme (Learn more...)
You must have administrative permissions to install an update.
Thu, Oct 20, 2011 at 1:43:30 PM | Revit 2009 Crashing In View Template Creation
kcaparella
Are you running the latest updates from autodesk? I was having this same problem with MEP 2011 not too long ago and once I installed the latest updates everything was good to go. Hope this helps! -kcaparella
Tue, Oct 25, 2011 at 11:45:51 AM | Revit 2009 Crashing In View Template Creation
tmassey
tmassey Avatar
thank you we uploaded the latest update and no problems now. all the best
View Template with automatically annotated families
Mon, Oct 27, 2014 at 3:50:30 PM
View Templates - Revit Architecture 2009
Fri, Jan 2, 2009 at 1:58:54 PM
View properties schedule- Revit Arch 2009
Thu, Oct 23, 2008 at 5:06:20 PM
revit crashing
Mon, Jan 23, 2006 at 2:28:30 PM
view template applied to each placed view
Thu, Jul 2, 2015 at 2:36:37 PM
Page generation time: 1.7240
