Forums >> Community >> Newbies >> Door and Window Tag
Wed, Oct 19, 2011 at 10:17:51 PM | Door and Window Tag
rcobbjr
3.5 Stars: 3 Votes
In Revit 2012, how do you create a reference bubble (window/door tag) that displays the Type or Type Mark in the upper portion of the reference bubble and the sheet number where the schedule can be found in the lower portion of the reference bubble?
Wed, Oct 19, 2011 at 10:34:36 PM | Door and Window Tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Door and Window tags can only display door and window information respectively.  For most categories of elements Revit doesn't yet allow you to link to parameters of other categories such as views/sheets in this case.
Whilst its possible to do this manually with a custom shared parameter added to doors/windows and manually entering the value to match with the view that corresponds with the schedule.  This can't be automated without using the Revit API.
Regards,
Chris.
Door / Window Tag
Tue, Mar 4, 2008 at 1:01:44 PM
Need help tagging/scheduling a door with a sidelite
Tue, Jun 8, 2010 at 2:15:22 AM
DOOR TAG QUESTION
Fri, Mar 1, 2013 at 7:32:19 AM
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:28 AM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
Page generation time: 0.9381
