Forums >> Revit Building >> Technical Support >> Aligning a label to Section-head
Tue, Oct 18, 2011 at 8:43:20 AM | Aligning a label to Section-head
Revin
Much respect to the genius who can solve this one...
See attached images.The first image shows our  company's standard section-head (drawn in AutoCAD).
I've created the section-head in Revit, along with two labels; one being the section-number inside the triangle; and the other being the drawing-sheet the section appears on,(aligned to the section-line). The second images displays the revit-drawn section-head.
The third image shows how the section-head is displayed after being loaded into the Revit-project. The section-number text needs to be fixed inside the trianlge (but kept readable ; ie. horisontal); and the drawing-sheet number label-text needs to be aligned & locked to the angle of the section-line. I cannot find any way of doing this (ie. locking a text to a point, or locking it to a fixed position in relation to a line with a changeable angle). No matter what I do, each time the section-line is at a different-angle, the label-texts are only shown in fixed relation to the original section-head start-point.
Can anyone solve this one?
Wed, Oct 19, 2011 at 7:44:40 AM | Aligning a label to Section-head
Shikari
This may be a stupid question but have you made a section head from scratch or have you just modified an existing one?
Wed, Oct 19, 2011 at 8:06:05 AM | Aligning a label to Section-head
Revin
I've tried both. Doesn't make any difference. The text / label remains the same.
Somehow there has to be a parameter to rotate the text/label to remain aligned to a line...
Thu, Oct 20, 2011 at 1:37:05 AM | Aligning a label to Section-head
Revin
C'mon guys; there has to be a genius somewhere out there...?
Thu, Oct 20, 2011 at 7:34:06 AM | Aligning a label to Section-head
Your only options are as described here: http://docs.autodesk.com/subscription/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58cadb753f8fc7f98a3be-7f81.htm
Wish we could say more.
Thu, Oct 20, 2011 at 2:25:00 PM | Aligning a label to Section-head
Revin
Thanks, WWHub. I guess there's no quick-fix for this one, then. Cheerio.
Aligning text a section head
Fri, Mar 2, 2007 at 1:17:11 PM
Section Heads label displays dashes rather than a label
Thu, Oct 12, 2017 at 1:01:46 AM
Trying to Import Filled Section Head
Mon, Jun 27, 2016 at 2:32:45 PM
problem with section head
Sun, Nov 26, 2006 at 4:49:05 PM
Reference Labels on Section Heads - MISSING
Tue, Dec 6, 2005 at 5:02:48 PM
Page generation time: 1.3946
