Forums >> General Discussion >> Revit Project Management >> applying colors in Filters in different floors in one project
Mon, Oct 17, 2011 at 5:44:40 AM | applying colors in Filters in different floors in one project
LOSpistos
I am using Revit Architecture 2012. I am currently working on one project, which consists of three floors.I need to set-up 'Filters' and 'View Templates' for wall/partition layouts and Fire Strategy layouts. I set up filters, and in Visibility and graphics properties, I define the colour fill for each filter category. All this I was adjusting in my ground floor.
Then I go to the first floor and I switch to the Filters tab and the filters are listed but not color fills are associated with each filter name, so I have to adjust again the same colors like in my ground floor. I am using a lot of different colors, so it is quite time consuming.
Is this a bug of the function, or am I doing something incorrectly? Or does anyone know of a different way of transferring filter/view template setting between floors? Cheers for any advice offered.
Luba
Mon, Oct 17, 2011 at 7:27:13 AM | applying colors in Filters in different floors in one project
View template settings are assigned manually, by view in the view properties.  Then simply apply the "default"  <Assigned> view template.
Mon, Oct 17, 2011 at 8:45:51 AM | applying colors in Filters in different floors in one project
LOSpistos
Thankss Smile
phase filters and lineweights
Fri, May 22, 2009 at 3:15:11 PM
System Colors
Tue, Sep 27, 2011 at 2:42:09 PM
Existing Filters into a Callout
Fri, May 10, 2013 at 10:22:07 AM
Filters in visibility graphics
Wed, Feb 4, 2015 at 7:43:00 AM
Lineweights For System Filters
Mon, Apr 20, 2015 at 2:28:08 PM
Page generation time: 1.7601
