17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> occupant load factor
28 Posts No Rating |
How do you create a field/parameter to a schedule that applies an Occupant Load Factor to already labeled occupancies? For example, I have rooms that I have identified as and Occupancy of 'A2- Assembly'. I want to identify the Occupant Load Factor of 1 person/15sf to that Occupancy type. Then my Occupant Load field will calculated the value between area/occupant load factor to give me the total number of occupants in the room. So, I just want to know how to create the Occupant Load Factor parameter.
Also, does it have anything to do with creating a Key Schedule? I took a webinar class about this, and I have notes about a Key Schedule.
You could add a project parameter to rooms - occupant load - and then have a key schedule that assigns occupant load based on the occupancy field.
How do you create a key schedule and how do you link it to the other schedule?
Occupant Load Factor Tag |
Thu, Feb 10, 2011 at 8:34:42 AM
Calculating occupant loads using room schedule |
Wed, Mar 7, 2007 at 4:45:12 AM
Room schedules and keynoting? |
Wed, Jun 4, 2008 at 6:45:01 PM
Room Tag with Occupant Load |
Thu, Feb 5, 2009 at 1:58:51 PM
room tag with occupancy info (2019) |
Thu, Jan 24, 2019 at 9:23:31 AM
