Forums >> Revit Building >> Technical Support >> Stairs - Matching Length to Minimum Required Risers...
Wed, Oct 12, 2011 at 10:10:59 AM | Stairs - Matching Length to Minimum Required Risers...
AlphaOjo
I have been doing stairs for a while now and usually just go with the shortest run required by code from floor to floor, but now I need to do a long set of stairs and am having trouble hitting the target number of risers.  Is there an easy way to just outline the length you want and let Revit calculate the minimum required riser height/tread depth?  Right now it seems to be a task of tediously fine tuning the "actual tread depth" to match teh desired number of risers...
I'm sure it has to be easier, but my training manual didn't go into depth on this topic... thanks!
Wed, Oct 12, 2011 at 10:18:31 AM | Stairs - Matching Length to Minimum Required Risers...
Because our code here is a minimum tread and maximum riser, we just use those two parameters and let Revit adjust the riser height, not tread length.
line based family help (length)
Wed, Aug 6, 2014 at 9:15:36 AM
Help w/ stairs [ 1 2 ]
Sun, Jan 9, 2011 at 11:47:33 AM
18
Stair Risers and Calculations?!! Very Urgent!
Tue, Nov 10, 2009 at 12:41:00 PM
External Fire Stairs
Tue, Nov 8, 2005 at 11:01:44 AM
Auditorium risers
Thu, Sep 1, 2005 at 4:45:26 PM
Page generation time: 3.6930
