Forums >> Revit Structure >> Technical Support >> temp dimensions
Wed, Oct 12, 2011 at 9:56:38 AM | temp dimensions
idraw38
Does anyone know in Revit 2011, if there is a way to set temporary demensions to start at wall core face while one is drawing walls? I know how to change the starting poit after the wall is drawn and then change the dimension of the wall. This seems like the long way around to get the wall to the desired length!
Wed, Oct 12, 2011 at 10:11:15 AM | temp dimensions
There is always a lot of information in the "Similar threads" listed below posts.  Tracing through those, you would have found: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17199
temp dimensions
Tue, Oct 11, 2011 at 10:05:25 PM
not enough space on temp for rendering
Wed, Feb 9, 2011 at 6:03:49 AM
Door Temp. Dim. Turned Off?
Fri, May 10, 2013 at 11:31:51 AM
Temp Dim's are too small
Mon, Jul 30, 2007 at 10:36:05 PM
temporary dimensions format
Sun, Nov 27, 2011 at 11:04:40 AM
Page generation time: 1.0365
