Forums >> Community >> Newbies >> Roof plan
Wed, Oct 12, 2011 at 9:11:59 AM | Roof plan
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2010. I am trying to create an accurate roof plan. In the roof plan, I want to show the walls under roof. When I add the roof, I attach the exterior to walls to the roof to eliminate the space between the wall and the roof. When I do that, the part of the wall that attaches to the roof is not visible in the roof plan where I need the walls to appear. Does anyone have a solution? Will I have to modify my view range?
Wed, Oct 12, 2011 at 9:29:31 AM | Roof plan
Roof plans typically do not show the walls below the roof so you are doing something unusual.  Your options are to underlay the floor below, to make the view wireframe (probably not good) or to change the roof in VG to transparent.
Fri, Sep 2, 2016 at 4:58:14 PM | Roof plan
rockthebuilder
You can even turn on your underlay, override lw, and then turn it off again and the lines you override will remain live.
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
Creating a Roof Plan in Revit
Wed, Oct 3, 2007 at 8:51:58 AM
missing roof in roof plan
Thu, May 7, 2009 at 11:40:59 AM
Roof slope different on roof plan and exterior elevation
Thu, May 28, 2020 at 5:22:40 PM
Page generation time: 2.2784
