Forums >> Revit Building >> Technical Support >> "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
Mon, Oct 10, 2011 at 3:20:16 PM | "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Hi All,
We're working on a project with a butterfly roof (see image 1) and are finding it impossible to create a roof by extrusion with square cut rafter ends. Normally I would use a roof by footprint, but since our roof pitch varies depending on the width of the building, the roof by extrusion would save us an awful lot of slope calculation and other inaccuracies. I've tried to fix this by setting the facia depth to match the roof thickness (this works perfectly in a roof by footprint) but it remains plumb cut (see image 2).
Any tips would be greatly appreciated!
Working in Revit Architecture 2011
Edited on: Mon, Oct 10, 2011 at 5:37:05 PM
Mon, Oct 10, 2011 at 3:21:59 PM | "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
*Working in Revit Architecture 2011
Fri, Jun 2, 2017 at 9:43:21 AM | "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I know this is super old, but any update on how to do this?  I too am looking at how to get this to be a square cut?  We have a curved barrel roof and it's showing a vertical fascia (plumb cut), when I want it to be square to the curve.
working in Revit 2017.
Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, Jun 2, 2017 at 10:10:30 AM | "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
I don't think thats going to happen automatically. You could include an in-place void.
Fri, Jun 2, 2017 at 11:03:31 AM | "Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
That worked!  Thank you!
Denver, CO
Revit Architecture
Fri, Jun 2, 2017 at 9:49:09 PM | lorne17
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting lorne17 from 2017-06-02 09:43:21
Thanks,
Lorne
It's working fine here (see pic), unless I totally misunderstood your question.
Mon, Jun 5, 2017 at 10:57:14 AM | pijpiwo
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting pijpiwo from 2017-06-02 21:49:09
That's weird.  Mine won't do that.  But the void worked fine for this project.  I don't want to spend too much time troubleshooting!
Thanks,
Lorne
Denver, CO
Revit Architecture
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:30 PM
Square Cut Rafters
Tue, Nov 20, 2007 at 5:45:45 PM
Roof Problems
Wed, Mar 5, 2008 at 2:07:33 PM
Rafter cut different on each side of roof
Tue, Jun 1, 2010 at 12:29:00 PM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Page generation time: 2.6452
