Forums >> Revit Building >> Technical Support >> Co-ordinate problems - miles out!
Mon, Oct 10, 2011 at 10:02:49 AM | Co-ordinate problems - miles out!
Oktober
I have imported an Autocad file with pegs with co-ords
I set the first peg up with specify co-ords, then when i go to annotate the other pegs are MILES out?
Mon, Oct 10, 2011 at 10:21:45 AM | Co-ordinate problems - miles out!
I have never heard the term PEG in conjunction with Revit or CAD.
Mon, Oct 10, 2011 at 5:15:15 PM | Co-ordinate problems - miles out!
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I agree with WW, peg is an interesting term. I will assume that you mean property corners. Usually, most of the survey data that I get is set up as 1" = 1'-0", some of the older programs did this for decimal convienence, perhaps this is your problem. Check to see if the survey data is 1/12th the size. You may have to scale data to get it to fit properly.
Ordinate Dimension Style
Mon, Sep 19, 2016 at 10:12:14 AM
Slow performance Revit 2014 XenDesktop
Fri, Oct 17, 2014 at 10:04:30 AM
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ]
Sat, Apr 17, 2010 at 7:29:52 PM
20
Trying to move Project location in not all revit files
Wed, Oct 16, 2013 at 10:52:13 AM
lines on topo surface
Tue, Aug 2, 2011 at 2:07:53 PM
Page generation time: 0.9798
