Forums >> Revit Building >> Technical Support >> floor finish showing though
Thu, Oct 6, 2011 at 11:44:41 AM | floor finish showing though
malcolm2286
Using Revit 2011. Bathroom floor plan. Vanity conuter families do not mask the wood floor finish.
Please advise. thanks
Thu, Oct 6, 2011 at 12:16:35 PM | floor finish showing though
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Please provide example, this can be done with a simple screen capture. Try Jing, it is what I use, and is free. I hope you are not using the detail tools but are really placing cabinets, and counter tops. Check your view setting should be hidden and not wireframe, next check your visual style button at the bottom and I like to have everything set to fine.
Thu, Oct 6, 2011 at 12:29:11 PM | floor finish showing though
If your counter family is only 2D, or if the 3D elements in the family are turned off and there is no masking region, then the family will not hide a floor.  Another possible problem is, how did you create your floor finish?  Is it modeled?
Finish Plan Problems
Wed, Jan 14, 2009 at 6:03:10 PM
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:14 PM
Finish Floor
Tue, Jul 21, 2009 at 5:05:38 PM
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:05 PM
Subfloor Vs Finish Floor Elevation
Tue, Jul 15, 2014 at 7:58:04 AM
Page generation time: 1.6383
