Forums >> Revit Building >> Technical Support >> Locking curtain Grids for resizing curtain walls.
Thu, Oct 6, 2011 at 3:49:26 AM | Locking curtain Grids for resizing curtain walls.
JRPcad
I'm sure this may have been covered before but i couldn't find an answer anywhere:
basically I've probably done a big nono by creating my building assuming a flat land (which it nearly is) as the survey company were taking a while to come back with the levels. What I now have are a few curtain walls that don't quite reach the external ground level. when I try to drag the curtain wall down to below ground (for visual reasons) it pulls all of the horizontal gridlines with it, even if I've locked them to ref planes. Why does this happen??? I would edit the provile of the wall but that seems to cause more issues than it's worth. My other work around is to place another wall beneath it and edit profile of that, but I don't want to as I just want to have the 1 wall.
Does anyone know of something I'm missing??
Thanks
Edited on: Thu, Oct 6, 2011 at 4:29:56 AM
For Architectural Services visit www.jrpcad.co.uk
Random Diagonal Curtain Grids in a Curtain Wall
Wed, Jul 6, 2011 at 6:57:03 AM
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
Curved Mullion within Curtain Walls
Mon, Oct 5, 2009 at 6:09:39 AM
non parallel curtain wall grids
Sat, Apr 28, 2007 at 12:54:05 AM
ACA Curtain Walls vs. Revit
Sun, May 4, 2008 at 8:20:27 PM
Page generation time: 1.6170
