Forums >> Revit Building >> Technical Support >> Sloped Building Pad
Wed, Oct 5, 2011 at 8:25:59 PM | Sloped Building Pad
Mephisto91
Hello,
So, I'm doing a building pad, but I don't want it to get sloped from edge to edge. What can I do to start the slope from a certain distance from the edge ?! I want that just the limits of the pad to get sloped.
Thanks
Thu, Oct 6, 2011 at 3:12:49 PM | Sloped Building Pad
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Your question is not quite clear. If you are talking about creating a grading plan for a site, that will be quite different than using pad in revit. Check out the add on by, SiteWorks. If you follow very carefully the steps to Graded Region in your user help, you can create a graded pad on a sloping site that will be able to give you quantities of cut and fill etc.
Edited on: Thu, Oct 6, 2011 at 3:16:58 PM
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Building Pad and Ecotect
Wed, Feb 2, 2011 at 11:12:06 AM
building pad
Wed, Dec 2, 2009 at 8:34:09 AM
Building pad, what is it exactly?
Mon, Dec 20, 2010 at 11:51:40 AM
14
Page generation time: 0.5793
