13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Family type name as shared parameter?
86 Posts No Rating |
Hello,
I thought I fully understood the way shared parameters work...until I ran into this:
I've made families, with multiple types in it. Now I want to add a shared text parameter to all off these families, that displays their type name. So I'add the shared parameter "description", and fill in the values for each family type. When I change the type, the value changes along. So far so good.
Now when I load the family into a project, the "description" value does NOT change along as I change types....?
How can I make this work?
Off course I know, I can also create a tag which reads out the family name, but I'd like to use the description parameter in multiple families, which can all be tagged by the same tag. Also; sometimes I also use description 2, or 3 (my tag reads 10 description fields), and this can be a diameter i.e. which is not represented in the type name....
Thanks!
did you use the overwrite parameter values when you loaded the familie into the project?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Nope,
also tested this in an new project...same results.
upload the familie?
peace is the path."
Mahatma Gandhi.
Whoops....
Dafpfy, you were right, I did not overwrite the parameter values...Thanks for pointing out!
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
Shared Parameter Over Constrained Planes |
Thu, May 18, 2017 at 2:13:21 PM
excluding a type in the family type parameter |
Thu, Mar 20, 2008 at 3:38:32 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Family-Type Parameter deleted |
Mon, Jun 3, 2013 at 5:04:18 PM
