Forums >> Workflow & Implementation >> Training >> walls
Wed, Oct 5, 2011 at 2:35:04 AM | walls
viktorik
1  what is the best way to join exterior walls of 2 in place masses, with different heights and angles
http://imageshack.us/photo/my-images/33/57018760.jpg/
http://imageshack.us/photo/my-images/20/54416137.jpg/
http://imageshack.us/photo/my-images/694/73846332.jpg/
2 an I make or find windows wit adjustable height width, and form, like poligons with mobile corners, if no, where to find
big windows ,big glass
Wed, Oct 5, 2011 at 2:36:59 AM | walls
viktorik
Wed, Oct 5, 2011 at 2:50:25 AM | walls
viktorik
masses are intersected, and walls too, if I trim extend to corner , it cuts the bigger wall by all the height
Wed, Oct 5, 2011 at 5:49:36 AM | walls
viktorik
Can I make windows with curtain walls + mullion?
Wed, Oct 5, 2011 at 11:58:17 AM | walls
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
this form could have been made by just using standard walls, I believe you can edit the walls like normal, so create a workplane at the face of the walls, name it, then use the framing view tool to create a view directly at the wall surface. then you should be able to cut the holes needed to create what you want.
Fri, Oct 7, 2011 at 9:01:02 AM | walls
viktorik
OK, THANKS , i MADE INTERSECTION OF 2 INPLACES, JOINED THEM AN THEN REFRESHED THE WALL TO THE NEW FACE WITH HOLE
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 0.4570
