13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Text Alignment - Linking with Parameter
Hi,
I have created a family using Detail component line based template. Also assigned some text to read the length using generic annotation family - Everything is working fine till here.
Now when load the family to project & change the length, the text reads the value but its location is not changing - refer attached snapshot..
Is there any way to link the text location - please advise
Now on the implementation stage.... |
in annotation familie you can make a group of the text and add in a invisible line in the group, i use that to allign text in annotation families
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Dafpfy nice trick!!! Thanks
Thanks Dafpfy & nasty
If you hover the mouse over the label then also it can be selected & locked to reference plane.
cheers
TEXT ALIGNMENT |
Thu, May 7, 2009 at 7:00:30 AM
text box leader alignment |
Sun, May 9, 2010 at 7:48:44 AM
Can a shared text parameter conconate other text parameters |
Tue, Dec 29, 2009 at 12:58:28 PM
Alignment of Text |
Mon, Sep 10, 2007 at 6:19:30 AM
Text as a yes/no parameter in a Tag |
Wed, Sep 29, 2010 at 11:02:06 AM
