Forums >> Revit Building >> Technical Support >> Transfering Schedules & Phases (2009)
Tue, Oct 4, 2011 at 5:04:41 PM | Transfering Schedules & Phases (2009)
JRoberts
We are using Revit 2009 and I am having an issue when transfering schedules from one project to another.
We have set up a master file (guide sheet) with our standard sheets and schedules. We then start a new project and uset he File -> Insert from View function to copy the sheets, views and schedules to our new project. However we are having issue with the phasing of the orginal schedules (in guide sheets) transfering to the new project.
I have the phasing of the guidesheet schedules set to "show new" but when they are inserted into the new project the phasing always changes to "show all" this is an issue because with have items that are phased as existing and new in the "new" project and only want new items to appear in the schedules.
any help or advise
J.
Wed, Oct 5, 2011 at 9:14:50 AM | Transfering Schedules & Phases (2009)
You should create your own template file rather than transferring.  It is much easier to do.
Wed, Oct 5, 2011 at 9:38:30 AM | Transfering Schedules & Phases (2009)
JRoberts
Yes, that would be the best way however our client has a template that we must use when we start all of our projects. So the template is out.
J.
Wed, Oct 5, 2011 at 10:47:28 AM | Transfering Schedules & Phases (2009)
I don't understand .... change your clients template adding the items you need.
Extracting Phases from a Template file
Thu, Jun 25, 2009 at 1:38:31 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
Room Numbering & Phases
Thu, Aug 27, 2015 at 3:01:49 AM
Phases and Schedules
Thu, Aug 26, 2010 at 1:31:11 PM
Page generation time: 1.2180
