Forums >> Revit Building >> Technical Support >> Spliting Objects for construction sequencing
Mon, Oct 3, 2011 at 4:32:30 AM | Spliting Objects for construction sequencing
Gils
Any tips and suggestions will be helpful.
I am looking for a logical solution how to split the model to be exported into Navis for simulation. e.g. the model contains single floor slab @ GL, however it is poored in two steps grid A-D and D-E. With curreent workflow to display that I would have to create two seperate pobjects.
I've heard that it may be possible to slice an object with a functionality within worksets workflow but I cant find it. Any advice?
Thanks in advance.
automatic number sequencing for beam marks
Mon, Feb 16, 2009 at 8:17:10 AM
4D in Revit???
Fri, Sep 5, 2008 at 12:01:35 PM
appearance of line types of existing objects in a "new construction" views
Sat, Feb 26, 2005 at 10:35:37 AM
Sheet set-up
Mon, Aug 1, 2005 at 6:23:44 PM
how to create video in stages of construction
Sat, Mar 21, 2015 at 12:27:46 PM
Page generation time: 0.1389
