Forums >> Revit Building >> Technical Support >> How to Scale Objects in Revit
Sun, Oct 2, 2011 at 5:41:16 AM | How to Scale Objects in Revit
architecthitesh
Hi Friends,
Mass objects or Families can not be scaled in Revit Architecture 2011 or 2012?
This is such a basic command in Autocad...but it is greyed in Revit when we select a mass object...
How to scale objects without Scale command?
Thanks.
Hitesh
Sun, Oct 2, 2011 at 9:27:55 AM | How to Scale Objects in Revit
This is not CAD - Revit is so much more than that limited program.  You can not scale model elements.  Some individual elements can be scaled in edit mode.
Wed, Sep 9, 2015 at 8:55:31 AM | How to Scale Objects in Revit
MERLYN
It certainly isnt, more the pity!
Wed, Sep 9, 2015 at 2:53:50 PM | How to Scale Objects in Revit
MERLYN,
Long time Revit users will smile at your post because we know something about your future.  If you can stick around long enough to actually learn Revit, you will no longer make comments like you made.
Good luck - I hope you make it.
Fri, Aug 25, 2017 at 3:48:48 AM | How to Scale Objects in Revit
Alfani81
I am new to Revit. I want to insert a lift on my plan. The lifts of the Revit library won't fit in my shaft dimensions. The properties of the lift have no option to change the dimensions. What should I do to fit an existing lift object in my shaft dimensions?
Another question I have, is that whenever I open a family object, the measuring tool is not active. How can I measure distances in family editor?
Thanks.
Fri, Aug 25, 2017 at 5:11:21 AM | How to Scale Objects in Revit
Alfani81
My repeated post is a mistake. I was just refreshing the page and it did post my message again.
Fri, Aug 25, 2017 at 6:05:59 AM | How to Scale Objects in Revit
tim123
4 Stars: 19 Votes
You will need to edit the family and change the dimensions there, or build you own lift family.  If you think about trying to scale something like a lift, it would not make sense, as everything would get smaller.  Typically a lift with smaller internal dimensions would not have thinner walls, which is what scaling would do.  To get started with family editing, click on the lift object and then 'Edit Family'.
Fri, Aug 25, 2017 at 10:51:46 AM | How to Scale Objects in Revit
CDWdavid
5 Stars: 5 Votes
Hi Alfani81,
"The lifts of the Revit library won't fit in my shaft dimensions. The properties of the lift have no option to change the dimensions. What should I do to fit an existing lift object in my shaft dimensions?"
Usually, a lift is a manufactured equipment, which means you should follow the manufacturer's dimensions to design your shaft. My suggestion is to select a specific model for your project first, then design you shaft around it.
Like a Garaventa lift, the Revit file from the manufacturer is an all-in-one family, which means it includes all models and sizes with diffrent options. You need to play with the family to create types for each model, such as Type-S-180-LH-Lower-RH-Upper, standard size, go-through, LH for lower gate, RH for upper gate, or Type-Mid-90-LH-Lower-LH-Upper, mid-size, 90 degree platform LH for both gates.
If it is an existing lift, then you need to field measure all dimensions, then design your shaft.
Edited on: Fri, Aug 25, 2017 at 10:56:13 AM
Fri, Aug 25, 2017 at 11:08:22 AM | How to Scale Objects in Revit
sllana
5 Stars: 2 Votes
alfani81, try this one
Fri, Aug 25, 2017 at 11:37:07 AM | How to Scale Objects in Revit
CDWdavid
5 Stars: 5 Votes
That 155559_Elevator10913 is a very good and sophisticated family for an elevator, and I used it as my base model family for our elevators.
However, like I mentioned in the previous reply, I modified that family based on the manufacturer's literatures such as Otis, which is in our specifications for our project standard.
For a specific project, we select the model first, then design the shaft based on that model.
Fri, Aug 25, 2017 at 1:13:47 PM | How to Scale Objects in Revit
Alfani81
Thanks sllana! I will try this and will let you know.
how to draw objects in the right scale?
Sun, Apr 10, 2005 at 9:38:18 PM
Export Revit to DWG - scale problem
Thu, Jul 17, 2014 at 4:35:23 PM
11
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
revit into photoshop to scale
Thu, Jul 19, 2012 at 12:37:09 AM
How to scale a family in revit?
Thu, May 5, 2022 at 6:26:59 AM
Page generation time: 1.6790
