14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Object Styles
I've attached a file that demonstrates a problem I'm having. I've imported a DWG file into Revit and I'm trying to change the Object Styles of the lines. Some lines work and others dont. You will see that I've changed the lineweight to 10 for two layers. Only the BUILDG_ layer works. Maybe someone can explain to me why the width of the DRIVEWAY layer won't change.
Post edited on 2005-12-02 12:50:32
Here's the DWG file.
Without looking at the files i'm guessing because that particular line isn't set to BY LAYER...?
That's right it's set to "BY OBJECT" how do I alter this setting?
Open the DWG and edit in AutoCAD and change to BY LAYER?
Change Default Family Category Model Object Styles |
Thu, Jun 18, 2009 at 4:23:45 PM
Object Styles: not implementing |
Tue, Jun 1, 2010 at 11:50:13 AM
Object Styles-Can't find where to change cut lines on sweeps-------------------- |
Mon, Sep 29, 2008 at 4:54:03 PM
Wall Object Styles |
Tue, Mar 7, 2006 at 11:29:56 AM
lines styles not printing or displaying |
Thu, Jul 17, 2014 at 8:50:30 AM
