Forums >> Revit Building >> Technical Support >> Need help with a PAT file
Thu, Sep 29, 2011 at 8:52:45 AM | Need help with a PAT file
esahnow
I'm in a bind here fellow Revitizers. I don't have AutoCad on my computer at the moment and need to create a .pat file for use in Revit 2012. I need a simple pattern if someone is willing to help me out and make it for me.
It is alternating bands of 3 1/4" and 11 1/4" (full scale) siding.
Also, for use in the model and elevation shots, do I need both a drafting and model pat file?
Thank you for you help on this!
Eric Sahnow
Project Lead/Designer
Thu, Sep 29, 2011 at 9:19:01 AM | Need help with a PAT file
TKennedy
4 Stars: 8 Votes
Hatch tool
Thu, Sep 29, 2011 at 9:34:58 AM | Need help with a PAT file
esahnow
Thanks for the link TK. I've never made a .pat file and would have no idea where to begin. I've seen some of the other posts on here about the file structure but I fear that this is way over my head. Any other help you could give me?
Am I remembering incorectly that there is a way to draw a pat file in Illustrator or Photoshop?
Edited on: Thu, Sep 29, 2011 at 11:28:38 AM
Eric Sahnow
Thu, Sep 29, 2011 at 10:29:16 AM | Need help with a PAT file
TKennedy
4 Stars: 8 Votes
That tool is an add-on for Revit, and it's about as easy as it gets for creating .pat files. You'll draw your hatch pattern in Revit, then it will make a .pat file for you.
Thu, Sep 29, 2011 at 12:55:36 PM | Need help with a PAT file
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I second this.  You draw the hatch with drafting lines to the exact scale you wish -- within a boundary box -- select all the lines, and tell it to make a hatch.  I've used it for realistic wood grains that aren't excessively wavy, LARGE swaths of cobbled rock walls that graduate in size.
This is an 8' x 30' model hatch pattern. crazy, huh?
once upon a time super-efficient hatch patterns might have been necessary for CAD machines that used vacuum tubes instead of microcircuits... (okay, that's an exaggeration,) but on today's machines this isn't really a problem, considering the other burdens a 3D model places on the memory and processor.
pic related.
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
.pat file
Mon, Aug 26, 2013 at 2:56:05 AM
pat file in revit 2010
Mon, Mar 1, 2010 at 2:00:08 AM
New pat pattern help
Tue, Nov 1, 2011 at 8:26:43 AM
Import .pat file
Fri, Oct 2, 2020 at 8:09:14 AM
Page generation time: 3.2835
