Forums >> Revit Building >> Technical Support >> Stacked walls
Thu, Sep 29, 2011 at 4:00:00 AM | Stacked walls
mathill
What are the pros and cons of using stacked walls? I confess I have never used them but when is it appropriate? We are talking simple 2 storey houses here.
Revit Architecture 2012
Thu, Sep 29, 2011 at 7:09:56 AM | Stacked walls
Stacked walls are good tools and you should have no problems using them in your limited projects.
Stacked walls are really simple walls that are stacked - in esscence grouped (not Revit GROUP) together.  As such, they can be "un-stacked" if needed and they return to simple walls but still in place.
Problems that can occur with stacked walls are when corner joins are not in the same location vertically.  Like when one level steps back fro the level below.  Another problem at corner joins occurs if the stacked wall has a profile sketch.  In these cases, the walls should be broken up so that each wall type works independently.
Remember, each individual portion of the stack is controlled by its wall type definition and will tag independent of the stack.  The stack itself is not taggable as a type.
Tue, Apr 16, 2013 at 6:10:23 PM | Stacked walls
NobleLP
I'm having trouble getting an area take off of walls in a stacked wall
they dont appear in the material take off or the schedule
Do I have to break up the stacked wall in order to get the areas of the walls?
Wed, Apr 17, 2013 at 1:20:02 AM | Stacked walls
ronmalit
5 Stars: 3 Votes
i dont think so..
i tried, and i can schedule my stacked walls individually
i suspect the phase filter is not set correctly.
** dont be mad, i dont have much... i am homeless
Wed, Apr 17, 2013 at 7:34:50 AM | Stacked walls
Did you read my earlier post?  Stacked walls ARE STACKED WALLS!  Not one item but two or more walls.  The areas will be of each individual wall in the stack.
Wed, Apr 17, 2013 at 10:26:58 AM | Stacked walls
NobleLP
I read other posts and realized that the "itimize each instance" must be checked to see the areas. not intuitive but as long as I get the numbers I'm OK
Thanks for the responces.
stacked walls
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls
Tue, Nov 25, 2014 at 5:51:10 PM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:35 PM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
Scheduling of Stacked Walls
Tue, Aug 18, 2009 at 2:16:01 PM
Page generation time: 3.8390
