14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Roof line
208 Posts No Rating |
Hi all,
Is there a way to show the roof outline on the ground floor plan without drawing each line in?
cadjockey
15 Posts No Rating |
You can click on view properties on your ground floor and select underlay and choose whatever plan your roof is in, this will show you the roof line.
Enran
the underlay method is not entirely foolproof we find, especially with rooves. another trick is to cheat a bit and adjust the view range briefly, draw your linework, and readjust view range. watch for any plan regions you may have though.
hope that helps - i think there was a long thread on this a couple of months ago too.
Thanks guys,
I thought this was the case. I was hoping there was a wiz bang setting I could use which meant I could avoid drawing individual lines.
cadjockey
Roof line not showing! |
Wed, Jul 19, 2017 at 7:16:01 AM
Line weights to roof |
Mon, Dec 5, 2005 at 8:30:49 PM
bottom edge of roof line weight |
Thu, Jul 12, 2018 at 9:28:31 AM
Wall Sweep/Siding up to Roof Line |
Fri, Nov 23, 2007 at 11:09:49 AM
Roof Cuts? |
Tue, Oct 24, 2006 at 3:17:47 PM
