Forums >> Revit Building >> Technical Support >> Massing Lines
Tue, Sep 27, 2011 at 6:32:07 PM | Massing Lines
Mephisto91
Hello
So, here is my problem. I'm drawing lines to transform into mass. Is there a way to do a "Start-End Radius Arc" with first point in one plane and another point in another plane in order to do a sort o "curved ramp" ?!
Thanks, Mephisto91
Tue, Sep 27, 2011 at 7:41:29 PM | Massing Lines
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You can probably do what you want easier with an in-place family, using the modeling tools. ie, sweeps, extrusions, swept blends, etc.
Swept blends are what you are looking for it sounds like.  You can start with one profile in one plane, and have it transform to another profile seemlessly along a curved path.   Or, not transform profiles, but only transform in terms of the height of the profile...
Massing has very limited applications in drafting from what I've seen.   I don't see it much used for conceptual modeling, either, as most people in authority positions to design have a high likelihood of being too old fashioned, and will prefer trace paper.  Fun to play with, however.
Connected model Lines in Massing Family
Mon, Oct 5, 2015 at 9:34:20 AM
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:55 PM
Drawing a hip rafter in massing
Tue, Aug 12, 2014 at 4:33:03 PM
Page generation time: 2.0837
