13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Glass Wall ????
1 Posts No Rating |
Is there a way to place a door on a curtain wall (glass wall), because i tried doing that in revit 8 but it doesnt work. Can someone plz help my project is due in a few days. Yout response will be greatly appreciated, Thank You.
It's certainly not as easy as door into a standard door - the door you place in the curtain wall needs to be the same size as the curtain panel you are inserting it into.
I find the easiest way is to take a default (curtain wall component) door, and save a new door with the panel's dimensions.
Hope that helps..
35 Posts No Rating |
you need to load from doors single or double glass doors
off course you can! and it's as easy as inserting any other door...
load the curtain door family,
put curtain grid in your curtain wall where you want the door to go in, what ever siz you have the door will fill.
put your mouse over where you want the door to go, tab until you get the glazing, from the drop down at the top change to door.
you can change any glazing to any type of wall you want as well that way.
HTH
Eldad is correct it's quite simple once you know how:
Here is some information from my blog http://revitrants.blogspot.com/
Curtain walls do not behave the same as normal walls and doors are not placed in the same manner. There are two options for placing a door in curtain wall.
In your modelling tab, place curtain grids to break up the panel to the size you’d like to make your door. Switch to a 3D view, hover over the edge of your curtain wall panel where you’d like to place the door. Now use the key to cycle through the various options to select the panel you’d like to change to a door. Now in the element drop down menu where it says System Panel: Glazed, change the panel to the appropriate loaded curtain wall door family. That’s it, now just adjust your grids appropriately to get to the correct size and apply mullions as appropriate.
The other option is to change the panel to a wall type. You may have noticed in the previous method you could pick from available wall types. If you change the panel to a wall you are then able to place doors as you would a normal wall. You could even make the door take up the full extents of the wall so it wouldn’t matter what wall type you actually used. There are issues currently with this method and schedule to and from room information of doors placed this way.
Glass Wall Join Issue |
Thu, Apr 10, 2008 at 11:15:38 AM
How to change glass wall to a frosted design? |
Wed, Dec 15, 2010 at 5:52:33 PM
Glass Block Wall |
Wed, Apr 20, 2005 at 12:04:41 AM
Curtain wall: Change the glass colour? |
Fri, Aug 27, 2010 at 10:13:57 AM
glass plank wall |
Sat, Sep 27, 2008 at 10:34:22 PM
