24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Wide flange columns only show if tops are connected
I have 1/4 masonry dimension plans but for whatever reason the only steel columns that show are the ones that have been attached to my roof decks. my simple solution is to connect all columns to decking of some sort.
Does anyone know a solution to get my unattached columns to appear otherwise?
Check the "show family precut" value isn't set in the family and whether the representation is from family or from project. Change it to From Project.
HTH.
Regards,
Chris.
ahh thank you Jedi Master, I can't believe I've never run across that issue before.
WT column - help? |
Thu, Jun 13, 2013 at 10:41:54 PM
Show Hidden Line - Not working the way I want it to |
Mon, Nov 19, 2012 at 10:52:43 PM
Historical Wide Flange sizes |
Fri, Aug 7, 2009 at 12:22:35 PM
composite columns |
Mon, Aug 31, 2009 at 10:17:41 AM
Floor Joists |
Tue, Apr 1, 2008 at 1:28:32 PM
