13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Line weights to roof
208 Posts No Rating |
Hi all,
As we know, you are able to show the individual layers of a roof makeup when in 'fine detail' view.
With good drafting practice one does not backline the top and bottom of the roof depth when in section if you are showing the makeup of the roof. You would backline the roof covering only.
Is it possible to set a pen weight to a specific layer?
cadjockey
Yes.
Override Host layers in your view settings...
Hi Mr Spot,
Can you please clarify?
When creating a roof style you have the ability to select a number of respective layers ie. roof finish, structure etc.
As you know these are assigned a material type eg. finish - roof slate
When manipulating the view settings do I need to create a sub-category within the object style 'roof' and call it 'roof slate' in order to set the pen wieght for this segement of the roof make-up?
This challenge also applies to ceiling.
Essentially I am wanting to have just one layer of the roof(or ceiling) to print with a heavier line weight in section. The roof lining or ceiling lining
cadjockey
Post edited on 2005-12-05 01:28:04
I have a similar question relating to walls. When you view them in elevation, I would prefer to have the surround (edges) in a heavier lineweight. Is there a way to do this?
At the moment all the wall and adjacent objects seem to be about the same lineweight
*** don't worry. worked it out.***
Post edited on 2005-12-05 02:09:33
Refer to attached image. No need to create subcategories - just enable this view override.
Hi Mr Spot,
This must be a version 8 function. I am running version 7
cadjockey
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Line Weights not showing in View |
Tue, Jul 8, 2014 at 12:45:18 PM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights |
Fri, Jul 20, 2007 at 12:06:07 PM
