Forums >> Revit Building >> Technical Support >> Revit Line ends
Thu, Dec 1, 2005 at 6:00:35 PM | Revit Line ends
bigbjohnson
When a line is drawn in Revit, the end of the line is a filleted end...its a half circle. in auto cad it is a square end. is there an option somewhere in revit to change the end type of a line?
Thu, Dec 1, 2005 at 7:12:06 PM | RE: Revit Line ends
eldados
eldados Avatar
4.5 Stars: 8 Votes
not that I'm aware off... but it shouldn't matter, you might see it in thick line mode on your screen and won't see the difference when you print.
Integrator
KarelCAD
Fri, Dec 2, 2005 at 3:29:59 PM | RE: Revit Line ends
bigbjohnson
well, if your line is really really big....then you will see the difference....i think Smile
Fri, Dec 2, 2005 at 3:57:49 PM | RE: Revit Line ends
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If your line is really big consider a filled region... This way you can use a fine line and a solid fill. But yes there should be an option...
Line ends squared off instead of round
Tue, Jan 2, 2007 at 10:52:47 AM
Line Based Family Joining at Ends [ 1 2 ]
Mon, Apr 6, 2015 at 12:47:20 PM
16
DIMENSIONING WALL ENDS
Wed, May 20, 2015 at 8:49:23 AM
Vertical hatch pattern line alignment on wall ends
Wed, Mar 14, 2012 at 10:04:07 AM
Hidden line types and export to autocad
Thu, May 4, 2006 at 10:22:40 AM
Page generation time: 1.5080
