Forums >> Community >> The Studio >> Schedule Width
Fri, Sep 23, 2011 at 2:30:44 PM | Schedule Width
izquierda74
I'm wondering if there is a way to standardize the widths of schedules on a sheet with multiple schedules.  I can't seem to find a way of snapping to guides or lines in order to align a vertical column of schedules.  I'm also interested in changing the font and size of the Title independently from the headings.
Thanks for any help you can lend.
Fri, Sep 23, 2011 at 3:18:26 PM | Schedule Width
TKennedy
4 Stars: 8 Votes
Unfortunately, the answer is no to both of your questions. This has been an issue for a while now.
If you are working with common schedules, make sure you set them up in your template. Even if you don't have standard sheets to place them on in your template, put them on a dummy sheet (you can delete it later), set the column widths (you'll have to eyball this, detail lines may help), then you can delete the sheet. The schedules will remember the column sizes even if they aren't placed, so when you later place them in a project they will be set up correctly. Duplicates of schedules will have their columns set the same as the original, so make sure the original is set right before you copy it.
Edited on: Fri, Sep 23, 2011 at 3:22:09 PM
Door width for double doors appearance in Schedule
Wed, Aug 5, 2009 at 10:49:53 AM
Wall Core Width in Schedule
Tue, Dec 2, 2008 at 1:10:22 PM
Door schedule/frame width
Wed, Mar 3, 2010 at 12:04:47 PM
Schedule column width: Sheet vs. edit view
Wed, Jun 25, 2014 at 1:00:04 PM
Width Override in Door Schedule
Fri, Jul 12, 2013 at 3:58:26 PM
Page generation time: 0.2004
