Forums >> Revit Building >> Technical Support >> Font mapping not working...
Fri, Sep 23, 2011 at 2:24:08 PM | Font mapping not working...
orlando1
I need to bring in AutoCAD details in Revit with simplex.shx, romans.shx fonts etc., and I have hundreds of 2D details.
I have changed the shxfontmap.txt and it converts the .shx fonts to .ttf fonts, but only when I explode the imported AutoCAD file. I could live with that but it creates dozens of additional font styles with the prefix of the AutoCAD file name. Can the fonts be converted without exploding? Or can the additional font styles be avoided?
When using the 'Link CAD' funtion, the fonts listed the shxfontmap.txt are ignored and substituted with something unknown. Is there a way to tell Revit which font should it use as a substituion?
Mon, Sep 26, 2011 at 11:08:07 AM | Font mapping not working...
orlando1
Still looking for an answer... Does the font mapping work only when the imported .dwg is exploded in Revit? Is there a way to get it to work without exploding?Attached is my font mapping file.Thanks.
Mon, Sep 26, 2011 at 11:18:28 AM | Font mapping not working...
Just a thought.  Did you set up the file before you linked the DWG?
Revit's help doesn't say anything about linked files, just imported.
Tue, Sep 27, 2011 at 10:00:41 AM | Font mapping not working...
orlando1
It works now!
The issue is/was that the converted font printed fattish on the screen and it printed that way when using the raster setting in the plot function. Once plotted using the vector setting the converted font printed ok. Conversion works with imported as well as linked files. However for some reason it does not quite show the true font as it should.
Campus mapping
Wed, Jul 11, 2007 at 5:15:22 PM
Make pattern&mapping bend
Wed, Oct 30, 2013 at 9:06:10 AM
Mapping Images
Sat, Nov 17, 2007 at 5:20:30 PM
Mapping Images
Thu, Nov 15, 2007 at 4:39:31 PM
Revit 2017 weird mapping in shape-modified floors
Thu, May 11, 2017 at 11:56:49 PM
Page generation time: 1.1122
