Forums >> Revit Building >> Technical Support >> pattern issue-void cutting through wall and sweeps
Fri, Sep 23, 2011 at 12:32:44 PM | pattern issue-void cutting through wall and sweeps
joe5676
Hey all,
I finally got the void to cut the sweeps on my wall, but now I need to figure out how to have it visually look right.  can anyone help me with how I can add a brick pattern onto my void or recessed wall section?  curiously it works on the brick sweeps, but not the wall itself
revit arch 2011
thanks - joe
Fri, Sep 23, 2011 at 2:08:38 PM | pattern issue-void cutting through wall and sweeps
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I would use the Paint tool to "paint" the material on the inside surfaces of the opening
Fri, Sep 23, 2011 at 2:15:45 PM | pattern issue-void cutting through wall and sweeps
joe5676
that sounds pretty simple.  but where is the paint tool?
Fri, Sep 23, 2011 at 2:24:08 PM | pattern issue-void cutting through wall and sweeps
joe5676
nevermind,  I found it.
thanks!
V. 2018 - cutting wall sweeps with void forms for stadium seating
Thu, Jan 11, 2018 at 12:50:20 PM
Cutting irregular openings in curved walls
Sun, Apr 9, 2006 at 7:45:39 PM
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:58:59 PM
In-Place Family sweeps issue
Tue, May 15, 2007 at 4:56:50 PM
Parametric Wall with random void pattern
Mon, Jun 16, 2014 at 3:31:31 PM
Page generation time: 0.9133
