Forums >> Community >> Newbies >> New to Revit, question about software
Thu, Sep 22, 2011 at 8:34:39 AM | New to Revit, question about software
settoon3
I have been using DataCAD to produce 2D residential construction drawings. I'm interested in producing 3D models, walkthru's ect., as well as construction documents for my residential designs. My question is what is the best way to go about it. Should I continue to use DataCAD or another program for the 2D drawings and use 3DS or Google SU for the 3D models, or will Revit do it all in one place? I don't need the BIM capabilities of Revit for Documents or Schedules. Would someone give me sugestions for the most efficient way to produce constuction drawings along with realistic renderings. Thanks for your time.
Thu, Sep 22, 2011 at 2:57:17 PM | New to Revit, question about software
First, revit can do it all.  In addition, if you have to do 2D work, Revit is easier than any CAD program I have ever used.  Most of the time, the 3D creates most of my 2D needs so I only think 2D in added detail work.
All that being said, is it a good fit for you?  It is not a cheap product because it really has a lot of power.  And for you, it might be like hitching a rickshaw up to a thoroughbred.  For a one man firm, the learning curve might be too steep.  You need other people around you to share the failures and successes.
Thu, Sep 22, 2011 at 3:35:41 PM | settoon3
vector25
vector25 Avatar
2.5 Stars: 7 Votes
Quoting settoon3 from 2011-09-22 08:34:39
"I have been using DataCAD to produce 2D residential construction drawings. I'm interested in producing 3D models"
What's wrong with DataCAD? DataCAD is all about producing a 3D residential model- in addition to 2D drawings..
Thu, Sep 22, 2011 at 3:45:46 PM | WWHub
vector25
vector25 Avatar
2.5 Stars: 7 Votes
Quoting WWHub from 2011-09-22 14:57:17
"You need other people around you"
if they're not like Hub.. lol jk..
Cost Estimating Software for Revit 2010
Fri, Jul 16, 2010 at 9:54:04 AM
Revit 2014 Deployment question
Mon, Dec 9, 2013 at 11:09:09 AM
Need recommendation on energy analysis software to work with Revit 2009
Fri, Oct 31, 2008 at 9:43:27 AM
FlexLM question
Tue, May 29, 2007 at 1:01:42 PM
Best Software for Modular houses?
Thu, May 13, 2010 at 9:30:01 AM
Page generation time: 1.5462
