Forums >> Revit Building >> Technical Support >> Reflected Ceiling Plan not showing revit link elements
Wed, Sep 21, 2011 at 1:51:04 PM | Reflected Ceiling Plan not showing revit link elements
Barbararq
Hi!I'm modeling a building and the structural elements where modeled in another archive (but still in RAC) that I linked in my architecture model archive.I need to see, at the 1st floor plan, the projection of the structural beams that are under the 2nd floor, so, I set the underlay to show the reflected ceiling plan of the 1st floor level, since these beams are showing at the ceiling.The view range top is above the bottom level of the beams. Why can't I see them, is it just because it's a link?
I checked all visual conditions and I also made a structural concret beam in the model, exactly like the ones in the link, and this one appeared just like expected to.Please, what am I doing wrong, I often get to know that the problem is not Revit, it's me.Thanks.
Barbara Ivo
Fri, Sep 23, 2011 at 11:15:36 AM | Reflected Ceiling Plan not showing revit link elements
Roxybeth
View Range is confusing for many people. I will be working on this myself in the next few days and will reply again if I figure it out!
Fri, Sep 23, 2011 at 11:59:06 AM | Reflected Ceiling Plan not showing revit link elements
Don't use the ceiling plan for the underlay, use a floor plan with the correct range.
Edited on: Fri, Sep 23, 2011 at 12:07:42 PM
Tue, Sep 27, 2011 at 7:59:17 PM | Reflected Ceiling Plan not showing revit link elements
Barbararq
Well, the problem wasn't me.
Bad news, as I was guessing:
"First off – Underlays don’t show linked models.  I tried copy/monitor levels, tried messing with Visibility Graphics, no way could I get a linked model elements to show in an Underlay.  It just didn’t exist as far as the Gods of the Underlay were concerned (Hades, Pluto, Osiris)."
http://rvit.wordpress.com/2011/02/02/underlay-action-slice-slice-baby/
Barbara Ivo
Mon, Dec 6, 2021 at 9:53:19 AM | Reflected Ceiling Plan not showing revit link elements
hanbyjm
It's 2021 and this is still a problem!
WWHub I tried your suggestion but not getting the range right.
Tue, Dec 7, 2021 at 6:55:56 AM | Reflected Ceiling Plan not showing revit link elements
This may help you with the problem:
http://www.cadspec.co.uk/user/user/index.php/2008/09/05/revit-view-range-explained.html
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Joined elements in Reflected Ceiling Plan
Fri, Nov 11, 2016 at 10:10:51 AM
Problem seeing doors in reflected ceiling plan
Mon, Jul 14, 2008 at 9:26:12 AM
REFLECTED CEILING PLAN
Thu, Jan 20, 2011 at 3:12:51 AM
Page generation time: 2.2536
